Discuss
icing up
 in
Refrigerator & Freezer Repair
Cannot find any info on this unit prhaps someone else will have more lick. You said you changed the timer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » icing up
  #1 (permalink)
Old 06-19-2010, 12:54 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Model Number: fr-3501   Brand: -other-   Age: 5 - 10 years
You said you changed the timer so I am assuming you have a mechanical defrost timer.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Ads By Google
Related Models
Frigidaire FR017RRW2 Wwh(v1) / Upright Freezer
Amana FR1065.000 COMMERCIAL MICROWAVES
Amana FR1100.000 COMMERCIAL MICROWAVES
Amana FR1110.A COMMERCIAL MICROWAVES
Frigidaire FRA052XT70 AIR CONDITIONER - ROOM
Frigidaire FRA052XT71 ROOM AIR CONDITIONER
Frigidaire FRA052XT710 ROOM AIR CONDITIONER
Frigidaire FRA052XT711 ROOM AIR CONDITIONER
Frigidaire FRA052XT712 ROOM AIR CONDITIONER
Frigidaire FRA052XT713 ROOM AIR CONDITIONER
Frigidaire FRA052XT714 ROOM AIR CONDITIONER
Frigidaire FRA052XT715 ROOM AIR CONDITIONER
Frigidaire FRA052XT716 ROOM AIR CONDITIONER
Frigidaire FRA052XT717 ROOM AIR CONDITIONER
Frigidaire FRA052XT718 ROOM AIR CONDITIONER
Frigidaire FRA052XT719 ROOM AIR CONDITIONER
Frigidaire FRA052XT72 AIR CONDITIONER - ROOM
Frigidaire FRA052XT720 ROOM AIR CONDITIONER
Frigidaire FRA052XT721 ROOM AIR CONDITIONER
Frigidaire FRA052XT722 ROOM AIR CONDITIONER
Frigidaire FRA052XT723 ROOM AIR CONDITIONER
Frigidaire FRA052XT724 ROOM AIR CONDITIONER
Frigidaire FRA052XT725 ROOM AIR CONDITIONER
Frigidaire FRA052XT73 ROOM AIR CONDITIONER
Frigidaire FRA052XT74 ROOM AIR CONDITIONER
Frigidaire FRA052XT75 AIR CONDITIONER - ROOM
Frigidaire FRA053PU10 ROOM AIR CONDITIONER
Frigidaire FRA053PU11 ROOM AIR CONDITIONER
Frigidaire FRA053XT70 ROOM AIR CONDITIONER
Frigidaire FRA053XT71 ROOM AIR CONDITIONER
Frigidaire FRA053XT710 ROOM AIR CONDITIONER
Frigidaire FRA053XT711 ROOM AIR CONDITIONER
Frigidaire FRA053XT712 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT713 ROOM AIR CONDITIONER
Frigidaire FRA053XT714 ROOM AIR CONDITIONER
Frigidaire FRA053XT715 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT716 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT717 ROOM AIR CONDITIONER
Frigidaire FRA053XT718 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT719 ROOM AIR CONDITIONER
Frigidaire FRA053XT72 ROOM AIR CONDITIONER
Frigidaire FRA053XT720 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT721 ROOM AIR CONDITIONER
Frigidaire FRA053XT722 ROOM AIR CONDITIONER
Frigidaire FRA053XT723 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT724 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT725 FRIGIDAIRE-RAC-OPP5
Frigidaire FRA053XT73 ROOM AIR CONDITIONER
Frigidaire FRA053XT74 ROOM AIR CONDITIONER
Frigidaire FRA053XT75 ROOM AIR CONDITIONER
Frigidaire FRA054AT70 ROOM AIR CONDITIONER
Frigidaire FRA054AT71 ROOM AIR CONDITIONER
Frigidaire FRA054AT72 ROOM AIR CONDITIONER
Frigidaire FRA054AT73 ROOM AIR CONDITIONER
Frigidaire FRA054XT70 ROOM AIR CONDITIONER
Frigidaire FRA054XT71 ROOM AIR CONDITIONER
Frigidaire FRA054XT710 ROOM AIR CONDITIONER
Frigidaire FRA054XT711 FRIGIDAIRE-RAC-OPP6
Frigidaire FRA054XT712 ROOM AIR CONDITIONER
Frigidaire FRA054XT713 FRIGIDAIRE-RAC-OPP6
Frigidaire FRA054XT72 ROOM AIR CONDITIONER
Frigidaire FRA054XT73 ROOM AIR CONDITIONER
Frigidaire FRA055XT70 ROOM AIR CONDITIONER
Frigidaire FRA055XT71 ROOM AIR CONDITIONER
Frigidaire FRA055XT710 ROOM AIR CONDITIONER
Frigidaire FRA055XT711 ROOM AIR CONDITIONER
Frigidaire FRA055XT712 FRIGIDAIRE-RAC-OPP6
Frigidaire FRA055XT713 FRIGIDAIRE-RAC-OPP6
Frigidaire FRA055XT72 ROOM AIR CONDITIONER
Frigidaire FRA055XT73 ROOM AIR CONDITIONER
Frigidaire FRA060XT70 ROOM AIR CONDITIONER
Frigidaire FRA060XT71 ROOM AIR CONDITIONER
Frigidaire FRA060XT710 ROOM AIR CONDITIONER
Frigidaire FRA060XT711 ROOM AIR CONDITIONER
Frigidaire FRA060XT712 ROOM AIR CONDITIONER
Frigidaire FRA060XT713 ROOM AIR CONDITIONER
Frigidaire FRA060XT72 ROOM AIR CONDITIONER
Frigidaire FRA060XT73 ROOM AIR CONDITIONER
Frigidaire FRA062AT70 ROOM AIR CONDITIONER
Frigidaire FRA062AT71 ROOM AIR CONDITIONER
Frigidaire FRA062AT72 ROOM AIR CONDITIONER
Frigidaire FRA062AT73 ROOM AIR CONDITIONER
Frigidaire FRA063AT70 ROOM AIR CONDITIONER
Frigidaire FRA063AT71 ROOM AIR CONDITIONER
Frigidaire FRA063AT710 ROOM AIR CONDITIONER
Frigidaire FRA063AT711 ROOM AIR CONDITIONER
Frigidaire FRA063AT712 ROOM AIR CONDITIONER
Frigidaire FRA063AT713 ROOM AIR CONDITIONER
Frigidaire FRA063AT72 ROOM AIR CONDITIONER
Frigidaire FRA063AT73 ROOM AIR CONDITIONER
Frigidaire FRA064AT70 ROOM AIR CONDITIONER
Frigidaire FRA064AT71 ROOM AIR CONDITIONER
Frigidaire FRA064AT710 ROOM AIR CONDITIONER
Frigidaire FRA064AT711 ROOM AIR CONDITIONER
Frigidaire FRA064AT712 ROOM AIR CONDITIONER
Frigidaire FRA064AT713 ROOM AIR CONDITIONER
Frigidaire FRA064VU110 ROOM AIR CONDITIONER
Frigidaire FRA064ZU110 ROOM AIR CONDITIONER
Frigidaire FRA065AT70 ROOM AIR CONDITIONER
Frigidaire FRA065AT71 ROOM AIR CONDITIONER
Frigidaire FRA065AT710 ROOM AIR CONDITIONER
Frigidaire FRA065AT711 ROOM AIR CONDITIONER
Frigidaire FRA065AT712 ROOM AIR CONDITIONER
Frigidaire FRA065AT713 ROOM AIR CONDITIONER
Frigidaire FRA073PU10 ROOM AIR CONDITIONER
Frigidaire FRA073PU11 ROOM AIR CONDITIONER
Frigidaire FRA07EPU10 ROOM AIR CONDITIONER
Frigidaire FRA07EPU11 ROOM AIR CONDITIONER
Frigidaire FRA082AT70 ROOM AIR CONDITIONER
Frigidaire FRA082AT71 ROOM AIR CONDITIONER
Frigidaire FRA082AT72 ROOM AIR CONDITIONER
Frigidaire FRA082AT73 ROOM AIR CONDITIONER
Frigidaire FRA083AT70 ROOM AIR CONDITIONER
Frigidaire FRA083AT71 ROOM AIR CONDITIONER
Frigidaire FRA083AT710 ROOM AIR CONDITIONER
Frigidaire FRA083AT711 ROOM AIR CONDITIONER
Frigidaire FRA083AT712 ROOM AIR CONDITIONER
Frigidaire FRA083AT713 ROOM AIR CONDITIONER
Frigidaire FRA083AT72 ROOM AIR CONDITIONER
Frigidaire FRA083AT73 ROOM AIR CONDITIONER
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Icing Kit install tminv Refrigerator & Freezer Repair 0 01-08-2010 02:38 PM
GE Monogram Icing Up perma Refrigerator & Freezer Repair 0 02-27-2009 01:33 PM
icing problem rich gosselin Refrigerator & Freezer Repair 1 01-23-2009 05:38 AM
Evaprator Icing Up valdo Refrigerator & Freezer Repair 6 11-22-2008 09:26 PM
Freezer is icing up. mikeschneider Refrigerator & Freezer Repair 0 10-11-2007 09:48 AM
