| » Water leaking from the back of the fridge |
Model Number: ET1FTTXKT01 Brand: Whirlpool Age: 5 - 10 years
Help!! We have a Whirlpool refrig that is leaking water out of some covered opening on the inside back of the refrig wall. What is causing it, and what do I need to do to fix it. Thank you!
Ads By Google Related Models Last edited by applejack : 06-18-2010 at 06:27 PM. Reason: forgot to indicate that it was leaking INSIDE the refrigerator |
Sounds like the drain (under the evaporator coils inside the freezer) is clogged and frozen up.
Remove the rear panel in the freezer and the freezer floor. Using a hair dryer, defrost the ice on the bottom and in the drain hole. Using a hot water make sure the drain is open. Check the bottom end of the drain hose which goes into the pan under the refrigerator (accessible from the back). Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ET1FTTXKT01 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 06-19-2010 at 04:32 PM. |
__________________
| Display Modes | |
| ice maker leaking under fridge at back of filter | rdteros | Refrigerator & Freezer Repair | 3 | 06-09-2009 08:05 AM |
| Water line on the back of my refrig is leaking | KSacker | Refrigerator & Freezer Repair | 1 | 04-02-2009 12:55 PM |
| water leak on back of fridge into icemaker | jan09 | Refrigerator & Freezer Repair | 0 | 01-29-2009 04:49 PM |
| water leaking in back and not filling the Ice tray | shatya | Refrigerator & Freezer Repair | 2 | 10-11-2008 12:53 PM |
| Water leaking from top/back of Fridg. thru vent type area's | alcon | Refrigerator & Freezer Repair | 1 | 04-19-2008 07:18 PM |
