How do I clean the coils underneath? They are filthy with dust and I can't get in with a vacuum far enough to clean them ? Scott
There are long brushes available that will let you get in at them. Something like a swiffer would also probably work. Part number: AP4320046
The way I clean mine is to remove the rear cover and the kick plate. I then foll the unit over to an open kitchen door and blow it out with a compressor. A leaf blower will also work. Most of the dust ends up outside. But you may not be able to do this due to your kitchen setup or there is a high risk that you will tear/scratch you kitchen floor. |
THIS FORUM IS DEAD!!!!!!! |
