Discuss
GE Replacement Compressor
 in
Refrigerator & Freezer Repair
Compressor WR87X10100 has 5 ports. One Chargeing Port, one suction, one discharge and two Oil Cooling. Can you send me
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Replacement Compressor
  #1 (permalink)
Old 07-23-2008, 05:45 AM
dhmwlm0429@verizon.net dhmwlm0429@verizon.net is offline
Junior Member
dhmwlm0429@verizon.net is on a distinguished road
Default GE Replacement Compressor
Model Number: GSS22sgmdbs   Brand: GE   Age: 5 - 10 years
Compressor WR87X10100 has 5 ports. One Chargeing Port, one suction, one discharge and two Oil Cooling. Can you send me a diagram or explain which is which. I removed the plugs shortly before begining to instal and want to be certain which is which.
I believe the bottom two ports are the oil, the top left is suction and the top right is discharge. Please confirm
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-23-2008, 08:37 AM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
That sounds right..the suction line is the big port on the left,it,s 5/16 inch. It is usually the port that is located above the process port..The right side is the discharge side[high side] normally a1/4 inch. below the high side is the oil lines also1/4 inch.Now the process stub can be use as a charging port. Some compressors you can also use it as a suction line.Unless instructions otherwise say not to use it as a suction port.
__________________
  #3 (permalink)
Old 07-23-2008, 09:46 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Here you go, I am looking at the installation instructions as I write this. Surprised your kit did not come with the instruction sheet......Looking at the compressor with the wire connections on the left side.... The port by the wire connections is the charge port. On the right side top is your suction line, and the one below it is your discharge port. The 2 ports on the right side bottom are your oil cooler lines, only used if the old compressor has an oil cooler, which it does not. so leave the rubber plugs on, if you removed the rubber plugs, pinch the ends and braze shut. Now the wire connections are as followed.....green attaches to the compressor, ground......orange is your nuetral to the start package and black is your Line to the start package. If you have a white wire that comes from a cap to the old compressor, cut it out it is not used for this new install......Hope this helps.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Refrigerator compressor replacement marster37 Refrigerator & Freezer Repair 11 09-13-2008 08:57 PM
hot compressor looking4answers Refrigerator & Freezer Repair 10 07-01-2008 11:31 AM
Wine Cabinet (Refrigerator) Compressor Replacement bcaln1 Refrigerator & Freezer Repair 1 06-30-2008 01:57 PM
frig and freezer warm,clicking noisefrom compressor,compressor very hot tdot Refrigerator & Freezer Repair 4 04-02-2008 09:35 AM
compressor replacement help kcaaac Refrigerator & Freezer Repair 2 11-14-2007 06:22 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
