Discuss
Secondary Valve, Ice maker
 in
Refrigerator & Freezer Repair
Hello, Can I use the water dispenser secondary water valve to input water to the ice maker for this fridge.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Secondary Valve, Ice maker
  #1 (permalink)
Old 06-17-2010, 05:42 PM
Junior Member
manila101 is on a distinguished road
Default Secondary Valve, Ice maker
Model Number: SXD26VW   Brand: Amana   Age: 5 - 10 years
Hello,
Can I use the water dispenser secondary water valve to input water to the ice maker for this fridge. I just replace the ice maker... and found out there is no water going in the ice maker. Since we are not using the fridge water dispenser I thinking swapping the valve... also since we are not using the fridge water... do i still need to replace the fridge water filter?
Please need advise.... Thank you...
Related Models
Amana SXD26VW REF - SXS/I&W
Amana SXD27NE REF - SXS/I&W
Amana SXD27NL REF - SXS/I&W
Amana SXD27NW REF - SXS/I&W
Amana SXD27Q2E REF - SXS/I&W
Amana SXD27Q2L REF - SXS/I&W
Amana SXD27Q2W REF - SXS/I&W
Amana SXD27TE REF - SXS/I&W
Amana SXD27TL REF - SXS/I&W
Amana SXD27TW REF - SXS/I&W
Amana SXD322L REF - SXS/I&W
Amana SXD322S2L REF - SXS/I&W
Amana SXD322S2W REF - SXS/I&W
Amana SXD322W REF - SXS/I&W
Amana SXD520NW REF - SXS/I&W
Amana SXD520SL REF - SXS/I&W
Amana SXD520SW REF - SXS/I&W
Amana SXD520TE REF - SXS/I&W
Amana SXD520TW REF - SXS/I&W
Amana SXD522VE REF - SXS/I&W
Amana SXD522VW REF - SXS/I&W
Amana SXD524VE REF - SXS/I&W
Amana SXD524VW REF - SXS/I&W
Amana SXDE25J REF - SXS/I&W
Amana SXDE25JB REF - SXS/I&W
Amana SXDE25JP REF - SXS/I&W
Amana SXDE27NE REF - SXS/I&W
Amana SXDE27NL REF - SXS/I&W
Amana SXDE27NPE REF - SXS/I&W
Amana SXDE27NPL REF - SXS/I&W
Amana SXDE27NPW REF - SXS/I&W
Amana SXDE27NW REF - SXS/I&W
Amana SXDE27QE REF - SXS/I&W
Amana SXDE27QL REF - SXS/I&W
Amana SXDE27QW REF - SXS/I&W
Amana SXDE522K REF - SXS/I&W
Amana SXDE522M REF - SXS/I&W
Amana SXDE526K REF - SXS/I&W
Amana SXDE526M REF - SXS/I&W
Amana SXDE528MW REF - SXS/I&W
Amana SXDT22H REF - SXS/I&W
Amana SXDT25H REF - SXS/I&W
Amana SXDT522J REF - SXS/I&W
Amana SXDT522K REF - SXS/I&W
Amana SXDT522M REF - SXS/I&W
Amana SXDT526J REF - SXS/I&W
Amana SXI20J REF - SXS/I&W
Amana SXI20NE REF - SXS/I&W
Amana SXI20NL REF - SXS/I&W
Amana SXI20NW REF - SXS/I&W
Amana SXI25SE REF - SXS/I&W
Amana SXI25SL REF - SXS/I&W
Amana SXI25SW REF - SXS/I&W
Amana SXP22H REF - SXS/I&W
Amana SXP25H REF - SXS/I&W
Amana SXPD20H REF - SXS/I&W
Amana SXPD22H REF - SXS/I&W
Amana SXPD25H REF - SXS/I&W
Amana SZ22MBL REF - SXS/I&W
Amana SZ22MBW REF - SXS/I&W
Amana SZ22ML REF - SXS/I&W
Amana SZ22MW REF - SXS/I&W
Amana SZ22NE REF - SXS/I&W
Amana SZ22NL REF - SXS/I&W
Amana SZ22NW REF - SXS/I&W
Amana SZ25M2L REF - SXS/I&W
Amana SZ25M2W REF - SXS/I&W
Amana SZ25ML REF - SXS/I&W
Amana SZ25MP2L REF - SXS/I&W
Amana SZ25MP2W REF - SXS/I&W
Amana SZ25MPL REF - SXS/I&W
Amana SZ25MPW REF - SXS/I&W
Amana SZ25MW REF - SXS/I&W
Amana SZ25NE REF - SXS/I&W
Amana SZ25NL REF - SXS/I&W
Amana SZ25NW REF - SXS/I&W
Amana SZD20J Ref - SXS/I&W
Amana SZD20K REF - SXS/I&W
Amana SZD20KB REF - SXS/I&W
Amana SZD20KP REF - SXS/I&W
  #2 (permalink)
Old 06-18-2010, 02:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I do not think you can swap the water valves because the tubes for ice maker and water dispenser are different. You can use the system without the water filter if you have a bypass plug which should be installed instead of the filter.
Here are the breakdown diagrams and Replacement parts for AMANA SXD26VW Ref - SXS/I&W | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 06-18-2010, 07:09 PM
Junior Member
Default
Thanks gene...
I would order the part.... do you know if the water to the ice maker is coming after it pass thru the fridge water filter? I dont know if i need to change the filter cause we are not getting water from the fridge anyway..
Thanks...
  #4 (permalink)
Old 06-19-2010, 12:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, the water goes through the water filter first and then goes to the ice maker and water dispenser. The water filter removes odor and a lot of a different unwanted parts of the tap water. I do not think you need them in the ice cubes as well as in the drinking water. You can order the new filter for about $35 and this not much money for at least six months protection.
- The water filter Part number: AP4310541
__________________
  #5 (permalink)
Old 06-20-2010, 06:17 PM
Junior Member
Default
Thanks for your help Gene... will order the the valve and filter...
  #6 (permalink)
Old 06-20-2010, 09:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #7 (permalink)
Old 06-21-2010, 12:36 PM
Junior Member
Default
Gene,
Do you also have the part# for the Ice maker water input valve for this fridge...
thanks again....
  #8 (permalink)
Old 06-21-2010, 01:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
These valves are shown as #83 & #103 on the diagram.
- The water valve before filter Part number: AP4013715
- The secondary water valve Part number: AP4013367
__________________
  #9 (permalink)
Old 06-21-2010, 03:56 PM
Junior Member
Default
Should I order only secondary water valve and filter?
I just replaced the ice maker and it made ice and dump after i put water on the tray manually also the water dispenser works...
Thanks..
  #10 (permalink)
Old 06-21-2010, 05:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Disconnect the water inlet tube from the secondary water valve and put it in a bucket. Swap the wires between the solenoids on the primary water valve. Depress the water dispenser lever and see if the water will come out. If it would, replace only the secondary water valve. If not, replace both.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing secondary water valve kit jameskearns Refrigerator & Freezer Repair 2 11-03-2010 11:38 AM
Primary & Secondary Water Valves dd5087 Refrigerator & Freezer Repair 0 01-21-2010 02:39 PM
Secondary Water Valve Von Hefling Refrigerator & Freezer Repair 6 07-10-2009 08:36 AM
How to clean secondary filter? Hanna Dishwasher Repair 2 04-20-2009 10:11 AM
water valve secondary Dermont Refrigerator & Freezer Repair 0 03-04-2009 07:24 AM
