| » Compressor Relay Arrangement |
Model Number: 7694010 Brand: Sears Age: More than 10 years
I Bought A Relay For The Compressor Motor.
There Are Three Pins On The Side Of The Compressor Where The Relay Wires Attach To. There Is One Pi On The Top And Two More On The Bottom. All Three Are In The Shape Of A Triangle.the Relay Itself Has Five Wires Coming Out Of It.two Black Ones On The Top Which I Figure Attach To The Power.the Other Three Wires Are Red For :run White For :start Black For :common Which Wire Goes To Which Pin ? Relay/ Overload Combination Made By Supco Part #ro41 One Qtr- One Third H.p. 115 Vac Solid State |
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog. |
The top pin is your common pin. You will need a meter to see which pin is start winding and run winding. The start winding pin ALWAYS has the HIGHEST resistance, the run winding pin has the lowest as measured from the common pin.
It is NEVER recommended to use a substitute start relay, always use the factory specified part. Your replacement part will not adequately protect your compressor by limiting the duration of an overload inrush current. Also it will not shut down the compressor on a thermal overload. I must admit I have used these "universal" kits before as it is almost impossible to stock all the different ones I would need. A final note, if you fail to wire in the run capacitor, your compressor will eventually fail.
__________________
- Last edited by richappy : 09-11-2007 at 08:11 PM. |
| Display Modes | |
| AMANA overload relay replacement | cc703 | Refrigerator & Freezer Repair | 2 | 04-24-2008 08:14 AM |
| Relay switch wont engage automaticaly to turn ac on per thermostat | lolo | Heating, Ventilation, and Air Conditioning (HVAC) | 3 | 01-16-2008 06:56 PM |
| how do you know if you have a compressor problem or if you just need more freon? | shane | Refrigerator & Freezer Repair | 1 | 09-10-2007 02:10 PM |
| Starter relay | tv guy | Refrigerator & Freezer Repair | 0 | 08-10-2007 02:08 PM |
