| » refridgerator evap fan |
Thanx for you reply. Motor was connected and still getting voltage. Let fridge run for awhile and check back later and evaporated fan was running at that time checked back later and evaporated fan again wasn't running but compressor was running. Evaporated coil had frost on top half but not bottom half my understanding is it should have light layer of frost over entire coil
need help with trying to resolve. Thanx |
Probably a freon leak. Wouldn't the compressor go out on low head pressure or is it that the evaporator fan stops and keeping the head pressure up
The evaporator fan has little to do with the system leaking. Common problem is evaporator, or internal tubing micro cracks. Usually causes ingestion of air that raises the head pressure.
__________________
| Display Modes | |
| evap fan- | cmcan1 | Refrigerator & Freezer Repair | 1 | 03-05-2010 02:07 AM |
| Evap Fan Motor | thumbrfg | Refrigerator & Freezer Repair | 0 | 04-08-2009 02:02 PM |
| evap fan motor | MMCMUSNRET | Refrigerator & Freezer Repair | 1 | 10-11-2008 12:45 PM |
| evap fan will not run | MMCMUSNRET | Refrigerator & Freezer Repair | 0 | 10-10-2008 07:30 PM |
| Noisy Evap Fan | hamm_6869 | Refrigerator & Freezer Repair | 5 | 09-19-2008 12:07 PM |
