Discuss
How to tighten a refer door handle
 in
Refrigerator & Freezer Repair
The one piece door handle is loose. It is a Whirlpool Designer Fit side by side. Model Number is 6C5HEXNB00.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » How to tighten a refer door handle
  #1 (permalink)
Old 06-14-2010, 12:21 PM
Junior Member
rswasey is on a distinguished road
Default How to tighten a refer door handle
Brand: Whirlpool   Age: 1 - 5 years
Thank you,
Ralph
  #2 (permalink)
Old 06-15-2010, 04:39 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I could not find any info on the given model number tried here and the Whirlpool site. Please check it.
Some handles have plastic inserts that pop or slide out to let you get to the handle bolts. Sometimes you have to remove a plastic end cap and thjen the insert will slide out.
Others are held by clips on the fridge door. To get the handle off you pull the handle up. Then tighten the bolts in the handle a little and reinstall it onto the clops. Be careful so you do not scratch your door.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how do i tighten handle on oven door range nettezz Oven Repair (including Ranges and Cooktops) 0 08-29-2009 09:23 PM
How to Tighten Fridge Door Handle gsgandarillas Refrigerator & Freezer Repair 1 05-16-2009 10:07 AM
How to tighten tub bolts richappy Washer Repair 3 04-25-2009 07:35 PM
Gurgling noise when shutting refer door mjr Refrigerator & Freezer Repair 1 08-31-2008 12:47 AM
How do i tighten the belt? TomC Washer Repair 1 08-19-2008 08:33 PM
