Discuss
Ice Cubes freeze together on the way into the ice box
 in
Refrigerator & Freezer Repair
The ice maker makes ice however, when the ice comes from the ice maker, the ice cubes freeze together on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Cubes freeze together on the way into the ice box
  #1 (permalink)
Old 07-21-2008, 03:10 PM
Blum Blum is offline
Junior Member
Blum is on a distinguished road
Unhappy Ice Cubes freeze together on the way into the ice box
Model Number: ARS2663AW   Brand: Amana   Age: 5 - 10 years
The ice maker makes ice however, when the ice comes from the ice maker, the ice cubes freeze together on the way into the box containing the ice. It makes a large ice ball. I checked the water line and it is clean and not clogged. Any suggestions? Thanks,
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-21-2008, 03:13 PM
Junior Member
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #3 (permalink)
Old 07-22-2008, 02:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Blum,
Remove the front cover from the ice maker. You'll see an adjustment screw on the right side of the ice maker control module. Turn this screw CW for about 180°. It should decrease amount of water coming into the ice maker.
Here are the break down diagrams for the Amana refrigerator Model ARS2663AW
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 07-22-2008, 08:59 PM
Junior Member
Default
Gene,
Thanks for the reply. I will let you know how it turns out. I appreciate you gettting back to me so quickly.
Thanks,
  #5 (permalink)
Old 07-22-2008, 09:32 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default It could be 2 things
It might be that their is an adjustment needed as suggested or it might be that the water valve itself is overfillling the icemold, the copper plate mounted behind the ice makers main drive wheel is coated with carbon buildup from arcing over time. Or the calcium/lime buildup in the water valve is causing it to over fill or it simply is leaking like an old faucet.What is happening is somehow water is dripping slowly onto the ice cubes and sticking them together. You must determine the cause buy using the suggestions posted above Kimosabe. Bon Chance mon ami!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Partial ice cubes stan1 Refrigerator & Freezer Repair 0 06-26-2008 10:27 AM
ice cubes larry218 Refrigerator & Freezer Repair 3 06-24-2008 04:38 PM
Ice cubes turn into clumps iamafallenangel Refrigerator & Freezer Repair 2 05-11-2008 12:37 PM
Ice cubes fogy Janek2 Refrigerator & Freezer Repair 1 04-18-2008 05:50 AM
Ice cubes in bin frozen together Mike20080325 Refrigerator & Freezer Repair 3 03-31-2008 01:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
