I have a kitchen aid side by side refidgerator. Both the refridgerator and freezer stopped cooling all of a sudden. Both fans are working and i cleaned out the lower condensor fins any ideas. thanx
If the compressor is warm but not running, you probably have a bad start device. Just pry off the cover on the side of the compressor and remove the start device with the run capacitor. Replacement AP4079373 If it looks burnt or rattles when shaken, it's bad.
