Discuss
Another K Aid ice dispenser problem
 in
Refrigerator & Freezer Repair
Initially the ice dispenser door would not close. With the dispenser door open there was substasntial ice build-up on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Another K Aid ice dispenser problem
  #1 (permalink)
Old 07-20-2008, 04:34 PM
mb250c mb250c is offline
Junior Member
mb250c is on a distinguished road
Default Another K Aid ice dispenser problem
Model Number: KSCS25FKSS01   Brand: Kitchen Aid   Age: 1 - 5 years
Initially the ice dispenser door would not close. With the dispenser door open there was substasntial ice build-up on the ice draw mechanism. Not realizing this I gave it a go after repositioning the lever so the flap would close. It seems like a circuit was tripped and a breaker has to be reset, because even after removing the ice buildup and freeing up the mechanics, the draw mechanism does not activate to dispense the cubes. I'm confident that there is no such breaker and am unsure what else to check.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-21-2008, 04:08 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does it dispense water or it's completely dead?
Does it make any noise (clicking, humming, etc) when you try to use it?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-21-2008, 06:34 PM
Junior Member
Default Respose to Gene
Water is fine.
No hum or any noise at all.
With door open, I depressed the door switch and pressed the ice dispenser, no noise or action with ice bin in or out.
  #4 (permalink)
Old 07-21-2008, 09:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the wire harness under the freezer door.
Remove the dispenser front cover and visually inspect all parts and wire harness.
If there is nothing wrong then the front cove assembly has to be replaced. In order to provide the right part number I need the color of the front cover.
Here are the break down diagrams fro the Kitchen Aid refrigerator Model KSCS25FKSS01
__________________
  #5 (permalink)
Old 07-22-2008, 05:27 AM
Junior Member
Default Response to Gene
Initially, in order to reposition the lever, I did disconnect wires and remove the bracket. I have since checked all connections and reassembled, to no avail.
The color of the cover assy is black. Looks to me like part #AP3126702.
Ouch! She's not a cheap date, that's for sure.
  #6 (permalink)
Old 07-23-2008, 02:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, the part number is correct. Keep us posted.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice dispenser problem lee c. Refrigerator & Freezer Repair 0 07-18-2008 07:47 PM
Water dispenser problem Nance Refrigerator & Freezer Repair 0 05-27-2008 10:52 AM
Water dispenser problem Noose Refrigerator & Freezer Repair 2 12-29-2007 01:45 PM
Soap Dispenser Problem Gator Dishwasher Repair 1 11-05-2007 12:58 PM
Ice dispenser problem FDAR Refrigerator & Freezer Repair 0 10-24-2007 08:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
