kaahurley
#1 Posted : Friday, June 20, 2008 7:37:24 AM(UTC)
kaahurley
I have a duet washer Model #GHW9100LQ1. It displays FH code. I have checked the valves on the water source and they are turned all the way on. I recently (about 3 months ago) replaced the water pump assembly. Now it is not draining well and the water trickles in. I can turn off the washer when the error comes on (about 11 minutes left) and switch it over to drain/spin. It will drain and spin fine. I did check the wire harness to the water inlet valve...i think it is okay. What else can I do? I have 5 kids and need my washer!
:o
#2 Posted : Friday, June 20, 2008 5:04:55 PM(UTC)
The "FH" error code means "No water detected entering machine or pressure switch trip not detected".
You have to perform the troubleshooting recommended by the manufacturer in the tech sheet.
Here are the break down diagrams for the Whirlpool Duet washer Model GHW9100LQ1
