Jay V
#1 Posted : Monday, May 12, 2008 9:48:11 AM(UTC)
Jay V
hi my range started acting up f1 f3 codes. unpluged and replace pulg worked good for a while. oven would light get to temp then not re-light. ingniter comes back on no gas. i replace oven vavle and circut board. didnt fix oven wont start unless tap vavle. you can blow out top burners like blowing out candles. it is like not enough gas?
SublimeMasterJW
#2 Posted : Tuesday, May 13, 2008 9:53:04 AM(UTC)
SublimeMasterJW
If your ignitor is mellow orange it may be bad. It should be as bright as the sun. Your oven sensor's quick plug could be contaminated with corrosion or grease. Clean it real good and retry.I bet the whole problem was a weak ignitor. APP-meters-circuit-tester.gif (13kb) downloaded 15,123 time(s).
SublimeMasterJW attached the following image(s):
You cannot view/download attachments. Try to login or register.
Gas Range requires 120V 15A yet comes with a Nema 14-50 Plug (Oven Repair (including Ranges and Cooktops))
by steveut 6/16/2018 11:15:02 AM(UTC)
Jenn-air Gas Range Error codes (Oven Repair (including Ranges and Cooktops))
by uncledave11 3/29/2018 2:48:39 PM(UTC)
frigidaire gas range (Oven Repair (including Ranges and Cooktops))
by Benitojuarez 1/27/2018 1:39:13 PM(UTC)
Kenmore Gas Range will not stay lit more then 5 seconds (Oven Repair (including Ranges and Cooktops))
by AlexMiles 2/28/2017 8:23:58 AM(UTC)
kenmore gas range (Oven Repair (including Ranges and Cooktops))
by dennishazard 1/5/2017 11:03:49 AM(UTC)
SAMSUNG gas range (Oven Repair (including Ranges and Cooktops))
by Dynutha 12/25/2016 6:13:18 AM(UTC)
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 12/14/2016 1:41:41 PM(UTC)
gas range won't stay lit (Oven Repair (including Ranges and Cooktops))
by nugentc 10/2/2016 5:07:17 PM(UTC)
Thermador gas range flames too high (Oven Repair (including Ranges and Cooktops))
by Sue24 8/30/2016 12:13:17 PM(UTC)
GE Gas Range Faulty Temp Readings and Slow to Heat (Oven Repair (including Ranges and Cooktops))
by yotimbo 2/9/2016 10:46:12 PM(UTC)
maytag gemini gas range wont light (Oven Repair (including Ranges and Cooktops))
by rtboten 9/25/2015 6:03:19 PM(UTC)
Gas Range Won't Heat up (Oven Repair (including Ranges and Cooktops))
by Bg20ball 9/9/2015 11:59:45 AM(UTC)
New gas range - humming noise (Oven Repair (including Ranges and Cooktops))
by andersonian 8/25/2015 11:19:37 AM(UTC)
oven door on gas range (Oven Repair (including Ranges and Cooktops))
by rewind1 6/8/2015 5:11:53 PM(UTC)
Frigidaire gas range will only ignite one at a time (Oven Repair (including Ranges and Cooktops))
by KevinD76 4/6/2015 11:07:28 AM(UTC)
