stove top is lighting and working. cannot get oven to ignite. trying to figure out if buying a gas valve or the igniter is the problem. thank you for your help
Originally Posted by: aer1227 stove top is lighting and working. cannot get oven to ignite. trying to figure out if buying a gas valve or the igniter is the problem. thank you for your help is there any other troubleshooting problems it may be
