MValley
#1 Posted : Thursday, August 16, 2007 10:36:10 PM(UTC)
MValley
Have a used Garage Sale Broan Trash Compactor. It seemed to work OK when I got it and then I tried to 'Compact' something I SHOULD NOT HAVE! :( Please don't ask me what it was but needless to say it was not soft pliable everday trash. The compactor now no longer 'compacts'. The electric motor still works and something inside is still spinning. the chain drive to the sprocket does not turn by itself except very slowly. I see something like a bearing through a hole spinning. I can put a socket on the sprocket nut and turn the compactor up and down and it seems to work OK but something has probably been busted by yours truly. I could probably tear everything apart if I wanted to but I'm not super mechanically inclined in these areas. I'm looking for a quick and cheap fix or this baby is going to the end of the driveway with a 'FREE' sign on it. Would love to keep it if I could though. :)
Admin / APP Team
#2 Posted : Friday, August 17, 2007 10:25:45 AM(UTC)
Admin / APP Team
Rank: Administration
Groups:
I would check the trunnion nut first. This manual might help.
- Trunnion nut for Broan 1050
- Gearbox
ge Trash compactor pedal broken can't open (Trash Compactor Repair)
by tahoemark 7/25/2017 1:13:08 PM(UTC)
Trash compactor won't turn off (Trash Compactor Repair)
by fgg 8/23/2014 8:14:29 PM(UTC)
Trash compactor gears (Trash Compactor Repair)
by jfkeats 3/27/2014 4:59:16 PM(UTC)
Kenmore Trash Compactor (Trash Compactor Repair)
by verna2198 2/10/2014 7:47:46 AM(UTC)
trash compactor (Trash Compactor Repair)
by ld.rob@@yahoo.com 1/2/2014 12:51:28 PM(UTC)
broan trash compactor (Trash Compactor Repair)
by SPELLINGRA 6/17/2013 4:00:48 PM(UTC)
Trash Compactor Solid Pack does not function (Trash Compactor Repair)
by frd1952 4/3/2013 3:19:53 PM(UTC)
Whirlpool trash compactor limit switch keeps failing (Garbage Disposer Repair)
by bhorenkamp 1/10/2013 3:18:53 PM(UTC)
trash compactor motor stops (Trash Compactor Repair)
by oldschool51 1/2/2013 2:08:03 PM(UTC)
by oceanhill 10/20/2012 11:03:21 AM(UTC)
jenn-air trash compactor broken gear? (Trash Compactor Repair)
by mljdd 4/19/2012 2:02:49 PM(UTC)
GE Trash Compactor won't stay on (Trash Compactor Repair)
by ddecker 12/9/2011 12:34:07 PM(UTC)
GE trash compactor ram doesnt return to top (Trash Compactor Repair)
by jlarkins 8/1/2011 12:04:29 PM(UTC)
Trash compactor will not come up (Refrigerator & Freezer Repair)
by amalifeline 6/26/2011 7:02:55 PM(UTC)
trash compactor wont run automatically when i turn the rotary switch on (Trash Compactor Repair)
by jdituri 4/24/2011 10:05:07 PM(UTC)
