thomwes2
#1 Posted : Wednesday, November 18, 2009 11:00:11 AM(UTC)
thomwes2
When we push the start button the dryer runs and fires only if you hold it on. It quits if you let the button up. I replaced the ignitor, flame sensor and coils. I have checked thermal fuse, and 2 thermostats. I think it has to do with the start relay but don't know how to remove or check to see if is is functioning.
thomwes2
#2 Posted : Wednesday, November 18, 2009 5:45:13 PM(UTC)
thomwes2
I finally got the start relay switch out. There is a bar you lift up and then twist it and it comes out. I pulled the switch apart and found that the coil wire was broken. I got a new switch relay and installed and it works like a champ
sidfink43
#3 Posted : Wednesday, November 18, 2009 6:56:34 PM(UTC)
sidfink43
Yeah, it is not intuitively obvious. Thanks for the update, because this is a common problem.
dryer won't keep running, overheats (Dryer Repair)
by readdream 9/21/2009 1:21:15 PM(UTC)
Kenmore Elite Dryer won't keep running (Dryer Repair)
by user22 9/11/2009 3:22:37 PM(UTC)
Kenmore dryer won't keep running after release button (Dryer Repair)
by cd195 5/2/2008 5:46:43 PM(UTC)
by mnovara 2/21/2008 11:30:12 AM(UTC)
