oilspotnm
#1 Posted : Sunday, August 12, 2018 2:49:48 PM(UTC)
oilspotnm
Two days after my amana washer starts making noise... my dryer will not start:mad: .
It makes a buzzing noise but fails to start. So I start watching videos and tear into it. I've confirmed that the Thermo fuse (or whatever they call that little fuse) is good with my volt ohm. I run the test on the door switch also and it checks out.
I went ahead and pulled the drum. Checked the rollers to make sure they're rolling free, the drums rotating freely on the felt guides etc. Everything checks out. Connections to the motor are good and I used my air compressor to blow everything in the motor etc. out. hoping that some dust or something was interrupting the points type connections on the motor controls. I reassemble everything, attempt to start the dryer and now the "buzz" to try to start the motor is hit or miss.
I'm out of patience to pull the motor at the moment, but I'm thinking the motors gone bad with no warning.
Any other thoughts on what could cause the problem before I tear the cabinet back of to pull the motor and start testing it? I didn't do it while I was in there because, well murphys law. I was pretty sure that I'd shatter the blower fan while trying to get it off.
I would like to note that the sharpening dept. at Amana, is doing a wonderful job in achieving edges as sharp, if not sharper, than a top of the line samurai sword!!!
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 6:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 12:12:45 PM(UTC)
by vassarrepair 2/2/2017 9:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 9:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 8:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 10:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 8:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 10:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 3:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 1:09:44 PM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 6:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 7:51:22 PM(UTC)
by saaman 8/21/2014 3:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 2:46:53 PM(UTC)
Maytag Stackabl Dryer will not start, Makes the dryer Buzzing sound LSE7806ace (Dryer Repair)
by mdmitchell 6/29/2014 2:08:33 PM(UTC)
