From all the research I've seen, I must be the only person to experience this. The other day my fridge got warm because my defrost heater went out, and the evaporator coils froze over. To make sure all problems in that circuit were fixed I replaced the defrost element, the bimetal defrost thermostat, and defrost timer. I plugged it in 24 hours ago. Fridge side is 38F, but freezer side only says 14F. Also, now my ice maker leaks water out the ice dispenser on the door.... What is wrong.
