gccch
#1 Posted : Wednesday, January 17, 2018 9:56:07 AM(UTC)
gccch
We were getting error code E24 which after researching is for pump out problem. However, the DW was pumping out just fine. We could add water and start the cycle and the water would be pumped out no problem. Two minutes into the cycle the code would come up a the time water fill is supposed to occur. No water fill. We checked the fill valve and during the process broke the valve, so we replaced it. No change. We were advised to change the control module. First try after replacing the module the machine made it to wash cycle with water fill and spray. Cycle was interrupted and we thought we were done. Next attempt same error code and no water fill. Any ideas?
Bosch dishwasher issue (Dishwasher Repair)
by kechke 12/4/2015 8:57:45 AM(UTC)
