joe ulland
#1 Posted : Wednesday, January 10, 2018 5:33:09 PM(UTC)
joe ulland
indeed 2 screws in the bottom at the rear of washer, look for 2 gray plugs and remove them by prying them off with a small flat head screw driver, loosen the 2 Phillips head screws, then push the water wall forward slightly, the water wall can be removed,install new water wall by placing the part as it should be on top of the spindle and gently move forward , the part will seat itself, then install the 2 Phillips head screws ,push the plugs in ,job is:) done
