jd514
#1 Posted : Saturday, January 6, 2018 2:16:52 PM(UTC)
jd514
Hi all,
Whenever the dishwasher runs, a small amount of water leaks underneath (about 1 cup throughout the full cycle).
I turned it over and saw a trail of soap or lime build-up which seems to indicate the source of the leak.
Here are image links:
[URL="[/URL]https://i.imgur.com/LTphw8H.jpg"][/URL]https://i.imgur.com/LTphw8H.jpg[/URL]
The first image shows the trail very clearly, coming from behind the larger white tank-like part. The second image shows the other side, where the leak might be originating near the top end of the spring.
This is a stand-alone dishwasher build in 1998! Can anyone tell me which parts are leaking, and/or how it can be fixed? Thanks!
ThatGuy
#2 Posted : Monday, January 8, 2018 1:04:08 AM(UTC)
ThatGuy
Groups: Expert
There is only one image.
type [img] then insert your url here and type [/img]
[IMG]https://i.imgur.com/LTphw8H.jpg[/url][/IMG]
Express Repair
#3 Posted : Monday, January 8, 2018 3:12:24 PM(UTC)
Express Repair
Hey,
Your dishwasher might be leaking for few reasons: Clogged air gap, Blocked sink, Wrong detergent, Check the filter, Blocked drain hose and Drain loop too high.
You can read more information in this blog: Common dishwasher issues
Appliance Repair Toronto
Thank you
ThatGuy
#4 Posted : Monday, January 8, 2018 4:20:21 PM(UTC)
ThatGuy
Groups: Expert
Originally Posted by: Express Repair Go to Quoted Post
Hey,
WRONG, WRONG, WRONG, and still WRONG!!!
These posts by "express repair" are spambot posts. They have very little to do with your actual problem and more to do with getting you to click their links.
Ignore them.
