Hi. My french Type fridge stopped cooling at all. No fault codes on display. Main PCB has LED flashing 6 times. Everything else seems to be working fine. Is the PCB the problem? Need to make sure before buying it. Sears will not give any advise because it is out of warranty. Anybody have a guess? Thanks.
RJC from PR
