Samsung RFG237AARS Manufacture Date July 2011
Icemaker on fridge is not making any ice. Water is working on the unit and makes it way to the ice maker assembly area, however is not freezing and creating cubes. I have tried resetting it using the Test button and the ice maker assembly recycles and is working. Based on problems areas for Ice Maker issues, I have replaced the following parts at separate times and neither have fixed the issue (returned each item when they did not fix the problem).
- Refrigerator Ice Maker Assembly (DA97-07592A) - Assy Case-Auger Motor (DA97-05246F)
Puzzled as to what the problem might be and beyond frustrated. What might be causing the water to not freeze?
