SHIFTADVISOR
#1 Posted : Saturday, November 18, 2017 4:46:17 AM(UTC)
SHIFTADVISOR
Kenmore Elite Model 110.67032601: Hello, I continue to have dryer SHUTDOWN
Error CODE is F 31
[ apparently by overheating ] when dyer shuts down, I use a Temp measuring gun getting 275 degrees at heater outlet inside dryer
I have REPLACED the heater coil 3 times [ 2 had broken wires after over heat ]
I have REPLACED 8557403 inlet THERMISTOR HIGH LIMIT STAT twice
I have REPLACED thermal fuse 8318314 twice
I have completely disassembled the dryer CLEANING OUT [ blower fan - dryer vent & hose ]
I have BLOWN out the dryer motor with air
I have CHECKED ALL above components with Ohm meter [ ALL ARE WHERE THEY SHOULD BE ]
Have so much money & time sunk in this, don’t want go for a new one..
ANY help would be appreciated
