DAN JENNINGS
#1 Posted : Tuesday, January 12, 2016 4:37:19 PM(UTC)
DAN JENNINGS
This dryer will not power up. I replaced the circuit board and still no power
#2 Posted : Wednesday, January 13, 2016 1:03:51 AM(UTC)
Have you checked the power?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !![/COLOR]!
