DGF
#1 Posted : Tuesday, December 8, 2015 10:44:13 AM(UTC)
DGF
I have a Samsung WF330ANW front loader - it is exhibiting all the symptoms of not getting power: dead panel, no error codes, totally silent....
The unit is out of the warranty period, but still relatively new (2.5 years old?).
The washer was in the middle of a wash cycle when it failed - with a full load of clothes and water....since removed.
I do have 110v at the downstream side of the noise filter.
I read that these symptoms can be caused by a bad display PCB, so I replaced this component as well as the PCB associated with the rotary dial - still no go, so I swapped out the main control board located at the rear of the unit - same results.
I have the service manual and wiring diagram, but don't see any internal fuses that might be the culprit. I presume that any safety cutouts - water level, open door, etc, - wouldn't disable the whole appliance, but I'm really struggling to know what to do next. Does anyone have any ideas?
Many thanks in advance for any guidance anyone can give.
Dave
DGF
#2 Posted : Monday, December 28, 2015 10:22:48 AM(UTC)
DGF
Quick update: I also replaced the main control board too - still dead as a dodo.
I have tried three times to get a technician out to my house, but each time no one showed up.
I also emailed Samsung support, but they don't even have the courtesy to respond or even acknowledge my email.
I'm getting to the point where I need to junk this piece of garbage - do any of the pros on the site have recommendations for a quality brand I should look at?
Dave
