ADS66
#1 Posted : Wednesday, September 30, 2015 5:54:08 AM(UTC)
ADS66
I have a WFW9400VE01 WhirlPool Duet Washer. It first gave a F71 error sometime during the night (wasn't even being used). We unplugged it and plugged back in and got a F70 error. After another round of unplugging and plugging back in, it shows no error, but just beeps when the power button is pushed. Reading another message on this forum(Appliance Ninja) about an identical model, I took the top cover off, and unplugged the blue wire harness labeled M3 connected to the control board in the right front corner. With this wire disconnected, the machine WILL power on and all the lights look normal. However when I connect the cable back it STILL will power on (but will not start a cycle). I had read that disconnecting this wire and having it power on points to the Motor Control Board. However I've also read that if the drum will spin manually (mine does), that isn't the Motor Control Board. So not sure how to proceed. Is there further troubleshooting I should do to determine the cause?
Thank you!
ADS66
#2 Posted : Saturday, October 3, 2015 8:36:22 AM(UTC)
ADS66
As an update, the washer has now gone back to displaying the F71 error after a couple days just sitting idle. Anyone have any help on trouble shooting this?
Thanks.
