Phoohbaby1
#1 Posted : Thursday, November 20, 2014 7:55:08 PM(UTC)
Phoohbaby1
I own a whirlpool supreme 8 cycle 2 speed motor washer and dryer pair and I had a leak in the front of my washer. So today I put a water pump on it. After doing so, put everything back together now it fills up with water but will over flow the basket if I don't stop it. It continue to fill with water even if I put it on small load. I will spin the water out but will not agitate on wash or rinse. Can you help me I love my washer and have taken good care of it.
Thank you
fairbank56
#2 Posted : Friday, November 21, 2014 1:18:30 PM(UTC)
fairbank56
Groups: Expert
Check the pressure hose that runs from the right rear part of the tub to the water level pressure switch inside the control panel. You may have pinched it or pulled it loose.
Eric
Reset washer machine (Washer Repair)
by Guest 3/16/2021 1:30:34 PM(UTC)
A GE washer machine cycles up until it need to spin and drAin .. just sits there (Washer Repair)
by Toomas72 3/5/2021 2:54:16 PM(UTC)
Kenmore washer machine , failing (Appliance Repair Companies - East of the Mississippi)
by Glasstooler 1/3/2019 4:55:02 PM(UTC)
Admiral Washer Machine Water Temp Not Working Correctly (Washer Repair)
by CRAIG1978 7/26/2014 11:08:17 AM(UTC)
Noisey washer machine (Washer Repair)
by Pavlo 3/28/2012 7:36:42 PM(UTC)
Washer Machine (Washer Repair)
by Allen12 1/17/2012 12:48:48 PM(UTC)
Maytag Neptune Washer Machine (Washer Repair)
by margioesc1973 10/9/2011 10:13:34 AM(UTC)
Whirlpool washer machine problem (Washer Repair)
by matogi7 9/23/2011 3:43:26 PM(UTC)
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? (Washer Repair)
by maddy 6/15/2011 9:11:07 AM(UTC)
Washer Machine timer won't turn off. (Washer Repair)
by garystarh 5/27/2011 7:25:24 AM(UTC)
Admiral washer machine (Washer Repair)
by 01queenie01 5/8/2011 9:14:49 AM(UTC)
My washer machine does not start (Washer Repair)
by Traci Thornton 4/17/2011 4:58:33 PM(UTC)
Washer machine will not fill with water (Dishwasher Repair)
by paisaac 3/29/2011 9:40:32 AM(UTC)
Washer machine (Dryer Repair)
by castillocm 8/13/2010 7:29:26 PM(UTC)
washer machine won't spin (Washer Repair)
by elbebe2525 1/6/2010 10:59:58 AM(UTC)
