mikem27
#1 Posted : Monday, September 8, 2014 9:42:56 AM(UTC)
mikem27
Hi and thanks for looking! I have a weird issue with my oven that started yesterday. We were cooking and all of a sudden the burners shut off (its electric). I turned the stove top knob off and the display went blank. When I turn the stove-top knobs on (any one of them) the clock and display come back on. It says that the stove is on, but it's not.
I checked the fuse panel (nothing was tripped). I checked all of the wiring and nothing appears to be burnt or loose. I left it unplugged and plugged it back in. . still nothing. I am assuming the control panel is shot, but I wanted to see if anyone else had this happen before or had any suggestions.
Any help would be greatly appreciated!
Thank you!
mikem27
#2 Posted : Tuesday, September 16, 2014 2:04:33 PM(UTC)
mikem27
Update, Just tried putting in a new display (control board) per some peoples recommendations and it does the same thing. Nothing turns on until I turn one of the knobs for the stove top, then the display lights up but nothing works.
anyone have any advice on where to go now?
#3 Posted : Tuesday, September 16, 2014 10:31:35 PM(UTC)
Here are your parts.
Check the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Sounds like the power is feeding through the infinite switch and element and powering the control board so you are probably missing L1 side of the line.
