viksstdmfn
#1 Posted : Monday, December 23, 2013 2:28:36 PM(UTC)
viksstdmfn
hi, I have a whirlpool duet dryer. when you turn it on the gas comes on for about 15 seconds and shuts off. I ran a diagnostic test and it displays an E3 error code. I tried way too many thing and am very frustrated, hopefully someone can help me out.
fortunately my old dryer has many compatible parts, but I replaced the thermal fuse, the thermistor, the high temp thermostat, coils, and flame sensor all with the same results. than I opened the top and removed the control panel. the service manual states an E3 code means a wrong part is installed. the control panel I removed is sn 3978918, however it looks like someone has refurbished this or made some changes there is marking on it with a sharpee.
Help im at my wits end and ready to use it as a boat achor, if it wasn't so heavy
sincerely john
Whirpool duet Dryer (Dryer Repair)
by Louiella 1/23/2018 4:55:01 PM(UTC)
Whirpool Duet (first gen) (Dryer Repair)
by jmden 8/23/2017 10:03:25 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 10:01:30 PM(UTC)
Whirpool Duet F70/F71/Beep Error (Washer Repair)
by ADS66 9/30/2015 8:54:08 AM(UTC)
Whirpool Duet Issues (Dryer Repair)
by joshhaye44 6/20/2015 2:11:50 PM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/26/2015 12:47:32 AM(UTC)
Whirpool Duet Washer new circut board wont work F11 code still up (Washer Repair)
by Rickvial88 7/10/2013 10:33:37 AM(UTC)
whirpool duet (Dryer Repair)
by jesquivel98 4/10/2013 12:43:06 AM(UTC)
Whirpool Duet (Washer Repair)
by spencer5 12/6/2012 9:15:05 AM(UTC)
Whirpool Duet Dryer - Just Stopped! (Dryer Repair)
by Gary Prentice 12/7/2011 9:37:20 AM(UTC)
whirpool duet f06 fault (Washer Repair)
by jeff and Susan Coffing 11/8/2011 7:32:51 PM(UTC)
whirpool duet washer door is not opening staying locked (Washer Repair)
by sonya46 10/23/2011 9:12:22 AM(UTC)
Whirpool Duet Sport Washer (Washer Repair)
by MBKeith 7/18/2011 12:51:09 PM(UTC)
Whirpool Duet Washer wont start (Washer Repair)
by smooothopr 6/8/2011 8:32:27 AM(UTC)
whirpool duet sport washer (Washer Repair)
by racnrob 12/24/2010 11:50:12 AM(UTC)
