Bonadu
#1 Posted : Monday, July 1, 2013 11:46:54 AM(UTC)
Bonadu
My refrigerator has been acting up from time to time. First it freezes milk then defrosts the freezer. I took the back off the freezer and noticed it was iced up. I checked a few links here and purchased control board, thermistor defrost heater and thermostat. When i removed the defrost heater it was burnt on both ends. I installed all the parts only for the the defrost heater to burn again. I ordered another and plugged it in and changed the thermostat again also.All connection were coated with RTV. The only thing that came on was the lights. I took out the new control board(which had lots of extra connections) and put the old one back in. Everything seemed fine until the defrost cycle. It started and iI smell burnt wire again. All item where check as instucted with ohm meter etc. All were in range so i don't know what else to check. Could it be an old smell? Water is pouring onto the heater when it defrost. Is this normal operations for the heater?:confused: :(
Bonadu
#2 Posted : Monday, November 4, 2013 9:26:44 AM(UTC)
Bonadu
OK I have a GE PSSMGMB BB refrigerator that is having lots of issues. I have changed the motherboard,Thermostat, heater and thermistors. The defrost heater keeps burning out.The smell is awful.It starts freezing up after a week or two and burns the heater again. What am I missing? Please help I can't afford to buy a new fridge right now.Please someone reply! I changed all parts with GE parts.
#3 Posted : Tuesday, November 5, 2013 2:02:59 AM(UTC)
Check the spade terminals to the heater, might be burnt.
Refrigerator Defrost Problems (Refrigerator & Freezer Repair)
by Albert M. 12/19/2007 8:54:06 AM(UTC)
