After we set it to self clean and it completed the cleaning cycle now it won't hear up at all. I checked the Electrical panel and there is a separate circuit for the oven, two 30amp breakers which were not tripped, I went ahead and tripped them and re-set the breakers but the oven still won't heat. everything else clock interior light ect is working.. but neither the broiler or the bake elements will get hot.. Suggestion?/ could it be the thermal over load of the elements?
Here are your parts Parts for Whirlpool RBS245PRB00 Wall Oven - AppliancePartsPros.comSee the attachment for the tech sheet. Yes odds are that it is the thermal overload. Also would be a good idea to check your oven sensor especially if the oven seems to run hot when you use it re: you either use a lower temperature or shorter time when baking. It could be that the oven needs calibrating, see the tech sheet. |
THIS FORUM IS DEAD!!!!!!! |
