I have a Maytag oven that has an upper and lower range, and only the upper range is not heating (broil or bake elements). The oven itself all has power, and it just says it's stuck in preheat, because the elements never heat up. The lower oven works fine. I've read several other posts about a similar problem, and they all seem to point to the control board. However, I'd rather not have to buy a $250 part if I don't have to. Is there something else that could be causing the problem? And I also couldn't find my model on the APP site.
Thank you!
Groups: APP Team
Hi.
Please look for the correct model number. What you posted is not a model number.
Simon.
Sorry, it took me quite awhile to find it. CWE5800ACE
Groups: APP Team
Hi. If you checked the wire harness from the control board to the elements and it's OK-replacet he control board/clock Part number: 7601M285-60
