Hi
We have a Simpson Eziset 750 washing machine which is leaking over the drum/tub. When the washing machine is spinning, the water is being spun over the drum/tub and is leaking down the inside of the machine cover onto the ground. When I move the drum/tub and look inside the machine I can see water along the inside of the machine cover. There is also water on the lid which indicates that the water is being spun high and over the drum/tub.**
Does anyone know what the problem could be?**
Thanks.
