Mr.Cha
#1 Posted : Friday, April 5, 2013 6:00:28 PM(UTC)
Mr.Cha
I have a maytag for about 2 years now, my washer will fill with water but won't agitate, spin, or drain i bought a new lid switch and replace it with the old one and its still doing the same, and when i turn it on for a little bit after the water fills i can smell this burn like rubber burn or electric burn, please help..
sidfink43
#2 Posted : Monday, April 8, 2013 7:24:34 PM(UTC)
sidfink43
I am thinking that there is something jammed in the pump, so check that out. If the pump is ok then the coupling may be broken and jamming things.
Here is the part along with a video that will show you how to get into the machine.
Part number: AP3961972
Maytag Washer Power Button (Washer Repair)
by wbaker08 2/19/2018 5:01:36 PM(UTC)
Maytag washer - Agitator spins, drum does not (Washer Repair)
by RandyTheHack 2/5/2018 2:08:24 PM(UTC)
Maytag washer agitates slowly (Washer Repair)
by hayley3 10/24/2017 6:56:40 AM(UTC)
Maytag Washer Centennial skips rinse cycle (Washer Repair)
by dmeech 8/21/2017 5:21:36 PM(UTC)
Maytag Washer (Washer Repair)
by michael christopher 8/20/2017 3:30:14 PM(UTC)
Help with maytag washer (Washer Repair)
by topcop12 5/5/2017 6:58:36 PM(UTC)
Maytag washer doesnt agitate in wash but works in rinse (Washer Repair)
by maytag21045 2/26/2017 10:14:55 AM(UTC)
Maytag washer has no cold water (Washer Repair)
by Calabashman 1/28/2017 5:29:58 PM(UTC)
Stacking Maytag washer/dryer (Washer Repair)
by sakinclancy 1/17/2017 5:09:37 PM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 11:29:35 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 8:14:31 PM(UTC)
Maytag washer trips house circuit (Washer Repair)
by derekirving 10/30/2016 11:17:28 PM(UTC)
Maytag washer fills / overflows by itself when off. (Washer Repair)
by Allyman 10/7/2016 7:31:30 AM(UTC)
Question Direct Drive Maytag Washer *very* weak agitation but does spin and drain (Washer Repair)
by bspead 9/25/2016 9:02:53 PM(UTC)
Maytag Washer spraying oil under washer (Washer Repair)
by C78 8/15/2016 3:04:43 PM(UTC)
