need wiring diagram for the switch ( m460-g) can't read schematic
THIS FORUM IS DEAD!!!!!!! |
have schematic, but don't know how to read it. I have a red, orange, and white wire to go into the timer to quick connects labeled a, b, and c. Which goes to which. The black wires are already attached. e-mail Scitekno@yahoo.com
Quote: I don't know how to read the schematic. On the back of the switch I have quick connect tabs labeled a,b, and c. I have 3 wires. One orange, one white and one red. Which goes to which? Thanks
The way the wiring diagram reads is: Red to B Orange to A White to C |
Thank you so much. The only other question that I will bother you with is that there are two positions on the b position, one on the bottom and one on the side. Does is make any difference?
I do not know. B does show 2 wires on it one goes to the power (L1) and the other goes to the interior light. When I look at the timer in the parts for this unit it does not show a connector on the side. Click on the below for more views of it. Part number: AP2107515
