wtester
#1 Posted : Monday, December 3, 2012 3:20:38 AM(UTC)
wtester
Dryer stopped working during a load had 1 mnute left on timer. turned it off unplugged it plugged back in, powers up all diplays work, light comes on and goes off when door is operated. Push start button ...nothing cant get a code either. Control board was replaced 3 months ago by service company
#2 Posted : Monday, December 3, 2012 4:55:30 PM(UTC)
Hello,
Remove the top panel and check the belt. If the belt is broken, the dryer would never work.
- The belt Part number: 8547168
wtester
#3 Posted : Monday, December 3, 2012 4:57:51 PM(UTC)
wtester
Thanks Gene, I will check but wouldnt the motor still try to run?
#4 Posted : Monday, December 3, 2012 5:05:17 PM(UTC)
No. It has a broken belt switch which interrupts power to the motor.
wtester
#5 Posted : Monday, December 3, 2012 6:49:38 PM(UTC)
wtester
Thanks Gene!! will look tomorrow
dryer wont run (Dryer Repair)
by gjack45pac 11/28/2015 9:40:28 AM(UTC)
by patriots 4/26/2015 10:21:36 AM(UTC)
Maytag Dryer wont run, burnt red wire from timer to temp control (Dryer Repair)
by Hurricane 9/4/2014 10:41:37 AM(UTC)
Kenmore HE4 Front load Dryer wont Run (Dryer Repair)
by hunterhutch 12/23/2013 6:19:04 AM(UTC)
dryer wont run control panel lights up (Dryer Repair)
by bobbijo 8/11/2013 2:13:57 PM(UTC)
Dryer wont run (Dryer Repair)
by jlp10 5/31/2011 4:34:08 PM(UTC)
by indybassin 2/21/2011 1:17:15 PM(UTC)
Maytag electric dryer wont run (Dryer Repair)
by crotonoil 12/9/2010 1:40:55 PM(UTC)
by latj 5/26/2010 5:11:49 AM(UTC)
by jgiff@att.net 1/25/2010 6:33:35 AM(UTC)
Maytag dryer wont run (Dryer Repair)
by Dennisb 1/5/2010 2:14:39 PM(UTC)
dryer wont run after making squeaky noise (Dryer Repair)
by pattie 9/18/2009 10:59:40 PM(UTC)
by nairobi 9/16/2009 2:02:01 PM(UTC)
dryer wont run at all (Dryer Repair)
by neighbor 9/16/2009 7:04:39 AM(UTC)
by danielle 10/22/2008 5:55:37 PM(UTC)
