My ovens only work if one burner is on ... If only turns on oven the igniter try for a few times than stops, same time the flame is on same is not Know if one burner is on before star ovens it runs fine. My Ωs on the valve are about 196 on both leads My igniter seems to me that runs too short and that gas has not arrive at the igniter yet to be ignitedor my iginate is bad? Thanks for your support on this matter Please drop me a note at my email if any person can help gauchousa@hotmail.com
Make sure the igniter is clean. If it would not help, replace the spark module. - The spark module Part number: W10331686
