The machine turns on, the door locks and NO water. We've turned machine off - replugged and nothing. Doesn't matter type of wash - tried them all. Checked the hoses and water supply and filters - all appear normal. I was told might be flow meter or inlet valve???? Thanks for any help!
Originally Posted by: FL mom The machine turns on, the door locks and NO water. We've turned machine off - replugged and nothing. Doesn't matter type of wash - tried them all. Checked the hoses and water supply and filters - all appear normal. I was told might be flow meter or inlet valve???? Thanks for any help! Forgot to say code comes up as F then goes to dL.
