My refrigerator's water dispenser has stopped working. My ice maker has not worked for years which is not as much of a concern to me unless it's easy to fix both. I have read a ton of forums on this but everyone elses dispenser at least makes noise when they push it, mine does not.
I have looked behind the fresh food drawer and the line does not look frozen or clogged. I have taken the filter out and it seems not clogged but I'm not sure how you can tell by just looking at it. The filter is about 6 months old. I have taken the cardboard of the back and all the lines seem clear and not clogged. It seems the problem is the water inlet valve by what I have read but how do I know this for sure? Does the fact that when the lever is pushed it doesn't make a sound mean it could be something else? Any help of how to move forward would be really appreciated!
Thanks in advance!
Groups: APP Team
Hi. Open the water and ice dispenser and check the control bracket pins holding the micro switches. The control bracket Part number: 2180226
This worked, thank you so much! it was the pins holding the switch in the control bracket. Quick question about icemaker not working. I pulled out the motor and it shows no resistence. Does it seem right that I need a new motor? Best regards, Andy Verleger Originally Posted by: Simon / APP Team Hi. Open the water and ice dispenser and check the control bracket pins holding the micro switches. The control bracket Part number: 2180226
Groups: APP Team
HI. I'm glad you where able to fix the problem. Regarding the icemaker - the reading on the motor should be near 4400ohm. Below find the attached instructions. Thank you. Simon.
