jakester3
#1 Posted : Tuesday, June 12, 2012 5:43:27 PM(UTC)
jakester3
Model GC2000XE3 / serial # FNW0316300 / whirlpool
The unit is 'locked up' - it will spin for several seconds and then stop. The chopping blade seems to be broken in two pieces. Is a new chopping blade available ?
Simon / APP Team
#2 Posted : Tuesday, June 12, 2012 7:04:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You will have to replace the hole unit.
Simon.
Garbage disposal not working (Garbage Disposer Repair)
by Guest 9/25/2021 4:06:35 AM(UTC)
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 12/14/2015 8:05:13 AM(UTC)
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 8/11/2014 3:23:39 PM(UTC)
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 7/20/2013 1:40:26 PM(UTC)
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 1/9/2013 8:47:55 PM(UTC)
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 6/26/2012 8:41:42 AM(UTC)
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 4/9/2012 12:40:32 PM(UTC)
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 1/31/2012 5:36:42 PM(UTC)
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 1/7/2012 11:24:18 AM(UTC)
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 11/13/2011 11:47:44 AM(UTC)
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 7/21/2011 7:19:58 PM(UTC)
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 6/22/2011 4:59:19 AM(UTC)
garbage disposals (Garbage Disposer Repair)
by shelterpup 1/4/2011 7:42:39 PM(UTC)
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 12/27/2009 8:12:02 AM(UTC)
by Linda French 10/12/2009 1:44:16 PM(UTC)
