I have a six year old GE washer that seems to have a problem in the slow agitate mode. When using the "test mode" for this unit all modes appear to work properly except the "slow agitate" mode. In the slow mode with the drive belt removed the motor starts to run and then stops and the starts again and repeats this continously. The reason that I am looking into this is that the lights in my home flicker with each start and also this seems to occur during normal operation when the time is down to 6 minutes. Just trying to determine if the motor is at fault or am I missing something?
