mctruzzi
#1 Posted : Tuesday, January 22, 2008 9:41:18 AM(UTC)
mctruzzi
I have a six year old GE washer that seems to have a problem in the slow agitate mode. When using the "test mode" for this unit all modes appear to work properly except the "slow agitate" mode. In the slow mode with the drive belt removed the motor starts to run and then stops and the starts again and repeats this continously. The reason that I am looking into this is that the lights in my home flicker with each start and also this seems to occur during normal operation when the time is down to 6 minutes. Just trying to determine if the motor is at fault or am I missing something?
Ge washer agitates, drains, sounds like it is trying to spin but doesn't (Washer Repair)
by juntjoo 8/20/2018 9:45:25 PM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 11:11:57 PM(UTC)
GE Washer leaks after sitting? (Washer Repair)
by redjada 4/11/2018 5:46:00 PM(UTC)
GE Washer lights allblinking (Washer Repair)
by DionJ 3/10/2018 12:47:07 PM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 10:09:50 PM(UTC)
GE washer refuses to Spin / Drain (Washer Repair)
by Ultimate2 9/18/2017 3:44:56 PM(UTC)
GE Washer repair (Washer Repair)
by jppablo4987 4/24/2017 2:40:39 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 12:23:21 PM(UTC)
How to reset computer on GE Washer Model GTWN5650F1 (Washer Repair)
by Bhargis 1/11/2017 6:22:14 PM(UTC)
GE washer won't stop filling, agitate or spin (Washer Repair)
by nmoreno24 10/14/2016 9:57:55 PM(UTC)
GE washer doesn't agitate or spin (Washer Repair)
by natestiles 8/25/2016 10:13:45 PM(UTC)
GE Washer - power button not working (Washer Repair)
by TerKow 8/10/2016 9:17:30 PM(UTC)
GE washer sounds like a freight train on spin cycle (Washer Repair)
by srbalsiger 7/30/2016 11:31:39 AM(UTC)
30+ Yr. Old GE Washer- Need Advice (Washer Repair)
by Not_Handy 7/24/2016 6:05:59 PM(UTC)
GE Washer - 4 Flashes on Motor (Washer Repair)
by Dickens 7/1/2016 1:29:50 PM(UTC)
