tom
thongluong
#1 Posted : Monday, March 26, 2012 5:01:23 PM(UTC)
thongluong
I Have a Ge Monogram Compactor. Right now when you hit run it is going down then keep cliking but not pullup, I have to turn off and hit run again to make it going up. What part that cause these problem. Please let me know so I can buy the part to fix it.
Thanks,
#2 Posted : Monday, March 26, 2012 7:58:39 PM(UTC)
Will the key switch return from the Start position to the Run position by itself?
Check the key switch for continuity between the "V" & "Y" terminals while the switch is in Run position. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric ZCG3300VWW-01 TRASH COMPACTOR | AppliancePartsPros.com
thongluong
#3 Posted : Saturday, March 31, 2012 6:36:59 PM(UTC)
thongluong
I open the swicth, there is 120V beetween Y and V, T-R and V. When I turn the switch to ON, there is no voltage beetween these switch. the motor lower the plate and it is not moving back up and keep ging a clicking noise, the knob is not turn back to OFF position. I have to manual to back to OFF and Then ON again so the motor can rising up to the top.
#4 Posted : Saturday, March 31, 2012 10:24:04 PM(UTC)
The switch with terminals "V" & "Y" is what it calls "momentary switch". Such switch must return to to its normal (open) position when released.
If it does not happen, the key switch has to be replaced.
- The key switch Part number: AP2037730
Whirlpool Dry-Miser Automatic Cycle (Dryer Repair)
by DavidMark 10/11/2018 9:25:40 AM(UTC)
Whirlpool Double Oven - Bottom Not Working (Oven Repair (including Ranges and Cooktops))
by kanderna 3/24/2018 12:58:57 PM(UTC)
leak from bottom of dishwasher (Dishwasher Repair)
by AlfredD 3/11/2018 9:23:12 AM(UTC)
GE Profile PFSS2MIXA. French door, bottom freezer. (Refrigerator & Freezer Repair)
by smytw1972 3/7/2018 3:27:30 PM(UTC)
Kenmore Bottom Freezer Frost Buildup (Refrigerator & Freezer Repair)
by EdBurkett 2/10/2018 10:54:23 AM(UTC)
Whirlpool Dishwasher has no power and there is water in bottom (Dishwasher Repair)
by Tracies12 1/27/2018 1:20:44 PM(UTC)
Whirlpool Side by Side door not sitting flush at the bottom (Refrigerator & Freezer Repair)
by Steinb54 12/31/2017 1:33:02 PM(UTC)
Timer not triggering spin cycle automatically (Washer Repair)
by syrist 11/2/2017 10:00:18 AM(UTC)
Refrigerator not cooling, bottom freezer over freezing and frosty (Refrigerator & Freezer Repair)
by Libboo 10/13/2017 5:51:02 AM(UTC)
Water in refrigerator, bottom freezer mount (Refrigerator & Freezer Repair)
by theboysmom3 9/14/2017 10:56:14 PM(UTC)
Refridgerator with confusing symptoms (Refrigerator & Freezer Repair)
by jingee007 8/25/2017 5:42:13 PM(UTC)
Whirlpool top load washer, wtw4800bq0, agitator bolt loose, and bottom moves (Washer Repair)
by Girliemom21 7/18/2017 8:57:17 AM(UTC)
Fridge/Freezer cool on bottom, warm on top (Refrigerator & Freezer Repair)
by tina8 6/22/2017 5:54:32 AM(UTC)
Bottom of freezer door sticks out (Refrigerator & Freezer Repair)
by smithd441@gmail.com 6/12/2017 12:23:24 PM(UTC)
Non-defrosting upright freezer not cold on bottom (Refrigerator & Freezer Repair)
by KOP264 6/12/2017 7:38:01 AM(UTC)
