Dianne
#1 Posted : Saturday, January 5, 2008 10:19:45 AM(UTC)
Dianne
My disposal is locked and the reset button does not release it. I have a tool for the disposal (a "Z" like tool??) but I cannot find how this might help. Any suggestions? thank you ~
kooler
#2 Posted : Monday, February 11, 2008 3:45:38 PM(UTC)
kooler
Hey Dianne, you should be able to look underneath the disposer and in the exact center locate where the tool can be inserted to manually move the disposer motor in either direction and hopefully dislodge whatever it is that has it locked up... Be mindful not to energize the disposer with this tool inserted in place and especially careful if you have to fish around inside the disposer to remove the culprit... cheers, kooler
hena
#3 Posted : Saturday, February 13, 2010 1:12:04 PM(UTC)
hena
Dianne, I have used a old broom handle in the past to gently tap the fins inside the unit. Try tapping both directions and this should free whatever is blocking the unit from working.Remember to do this with the unit off and never, ever insert your hands into the disposer!
Good luck
JOE
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 12/14/2015 11:05:13 AM(UTC)
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 8/11/2014 6:23:39 PM(UTC)
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 7/20/2013 4:40:26 PM(UTC)
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 1/9/2013 11:47:55 PM(UTC)
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 6/26/2012 11:41:42 AM(UTC)
by jakester3 6/12/2012 8:43:27 PM(UTC)
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 4/9/2012 3:40:32 PM(UTC)
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 1/31/2012 8:36:42 PM(UTC)
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 1/7/2012 2:24:18 PM(UTC)
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 11/13/2011 2:47:44 PM(UTC)
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 7/21/2011 10:19:58 PM(UTC)
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 6/22/2011 7:59:19 AM(UTC)
garbage disposals (Garbage Disposer Repair)
by shelterpup 1/4/2011 10:42:39 PM(UTC)
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 12/27/2009 11:12:02 AM(UTC)
by Linda French 10/12/2009 4:44:16 PM(UTC)
