res04n70
#1 Posted : Tuesday, December 27, 2011 8:17:42 AM(UTC)
res04n70
Maytag clock controll, some of the buttons quit working. some still work. Clock keeps time but you can't set it because clock button is inop. Numbers 1,2, and 3 still work. all other buttons on this pannel don't work. Upper and lower oven functions are same with some work some don't. If I kill power for 15 - 20 minutes all functions return and everything works. After a cook cycle completes like "Toast with autoset" the same buttons become inop again. Is it time for a new clock controll or may I be overlooking something?
ApplianceJunk
#2 Posted : Tuesday, December 27, 2011 8:31:36 AM(UTC)
ApplianceJunk
Maybe a bad solder connection on the clock or if there is a ribbon cable for the buttons you could try cleaning it, but I would guess the clock will need to be replaced.
