Whirlpool oven- The top element in the top oven will not go off even though the control panel seems to be working properly . While baking at 300 degrees the oven became too hot, F3 error code, and the only way to turn off the oven is to turn off the circuit breaker. Would a faulty sensor keep the oven from being turned off? Or do I have a control panel problem? Or both?:confused:
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
THIS FORUM IS DEAD!!!!!!! |
Ok, thanks for the quick reply. I have a new control board on order.
