boatman1001
#1 Posted : Tuesday, May 12, 2009 12:59:09 AM(UTC)
boatman1001
Side by side, water leaking from freezer door. Has water and ice dispencer in freezer door. Help!
woodchuckie
#2 Posted : Tuesday, May 12, 2009 7:28:45 AM(UTC)
woodchuckie
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Frigidaire - Water Leaking from Electronic Defrost Control Area????? (Trash Compactor Repair)
by BJPrice 2/1/2018 6:20:07 PM(UTC)
Washer water leak and freeze on sensing mode (Washer Repair)
by JoeOfCola 10/9/2017 1:50:48 PM(UTC)
Water leaking from brand new LG door in door fridge (Refrigerator & Freezer Repair)
by Jason B 7/20/2017 3:58:06 PM(UTC)
Front Door Water Leak (Refrigerator & Freezer Repair)
by nebblkshts 6/15/2017 11:56:18 AM(UTC)
Freezer with ice on inside and water leakage (Refrigerator & Freezer Repair)
by Woodhead98 1/4/2017 6:02:15 PM(UTC)
Samsung water leak (Refrigerator & Freezer Repair)
by bobyoder 10/11/2016 9:45:57 AM(UTC)
Water leak from top housing near filter. (Refrigerator & Freezer Repair)
by Ledzepx 4/6/2016 11:54:50 AM(UTC)
Refrigerator water leak. (Refrigerator & Freezer Repair)
by freddie long 1/22/2016 3:31:36 PM(UTC)
Water leak from top housing near filter (Refrigerator & Freezer Repair)
by leejackson 1/17/2016 10:13:27 AM(UTC)
Water leak under dishwasher tub (Whirlpool WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/25/2015 7:08:04 PM(UTC)
Water Leaking at Water Inlet Valve (Refrigerator & Freezer Repair)
by marshmore 12/24/2015 11:00:34 AM(UTC)
water leaking? in freezer (Refrigerator & Freezer Repair)
by chknmom 10/16/2015 6:50:20 PM(UTC)
Water leak from front bottom of drum assembly (Washer Repair)
by Russ-Austin 10/7/2015 10:17:31 AM(UTC)
Whirlpool intermittent water leak (Refrigerator & Freezer Repair)
by UnclePen 9/26/2015 6:06:44 PM(UTC)
water leaking on floor (Refrigerator & Freezer Repair)
by capetish 8/23/2015 9:39:00 PM(UTC)
