grant
#1 Posted : Monday, November 26, 2007 9:37:34 PM(UTC)
grant
maytag washer has developed a severe grinding noise on the spin cycle is it something that can be repaired or is it finished
thanks for the help
grant
#2 Posted : Tuesday, November 27, 2007 5:42:30 PM(UTC)
Most likely the problem with your washer is a bad pump bearing.
Lift the washer up from the front, remove the belt and rotate the pump pulley manually. If you feel any tension, replace the pump.
- The part number for the pump AP3447809
- Here are the break down diagrams for the Maytag washer Model MAV6200AWW
grant
#3 Posted : Tuesday, November 27, 2007 7:49:31 PM(UTC)
grant
thanks a lot Gene,you were correct the pump is bad, saved me a bundle
Whirlpool Duet Sport Washer problems (Washer Repair)
by bdmbluegrass 1/11/2017 2:54:22 PM(UTC)
washer problems (Washer Repair)
by porterbridges 1/18/2015 1:53:23 PM(UTC)
Washer Problems (Washer Repair)
by Revelation320 9/4/2013 7:41:04 PM(UTC)
Commerical Washer Problems (Washer Repair)
by sherryash 12/18/2012 6:11:25 PM(UTC)
by mariela 10/24/2012 10:44:31 PM(UTC)
Bosch Dishwasher problems (Dishwasher Repair)
by Manuel Arce 9/15/2012 12:14:41 PM(UTC)
Whirlpool dishwasher Problems (Dishwasher Repair)
by captbud 8/1/2012 1:21:44 PM(UTC)
by malon66 6/21/2012 9:17:18 PM(UTC)
WP Ultimate Care 2 washer problems...new timer didn't fix (Washer Repair)
by HunterTinsley 4/6/2012 9:11:49 PM(UTC)
Whirlpool Washer Problems (Washer Repair)
by GK12 3/4/2012 4:28:37 PM(UTC)
LG Dishwasher problems HELP! (Dishwasher Repair)
by djmcheme 11/19/2011 2:05:29 PM(UTC)
Intermittent washer problems (Washer Repair)
by rscha787 10/12/2011 8:56:35 PM(UTC)
by jamesnl 10/9/2011 5:13:43 PM(UTC)
maytag washer problems (Washer Repair)
by djv106 9/24/2011 10:40:00 AM(UTC)
by SAYRES 9/11/2011 8:52:04 AM(UTC)
