ctct703
#1 Posted : Thursday, September 27, 2007 4:20:45 AM(UTC)
ctct703
Dryer works fine except it will not heat. This is an electric dryer. The heating element and sensor at the element both ohmn out to be good. What else?
#2 Posted : Friday, September 28, 2007 1:00:37 AM(UTC)
Make sure you get 230 volts to the dryer. If ok, check the thermal fuse and heating element for continuity. You can click on your model # above to get parts.
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
